Switch off visibility of assembly part across multiple idw views
It would be useful to switch off the visibility of a component/componenets in an idw containing many views of an assembly, in a single click. Without having to expand each view, BOM, then deselect the parts manually. Apologies if this can already be done!!
5 Comments
swalton
It is already in Inventor
  1. Create Design Rep Views in your assembly.
  2. Pick the appropriate Design Rep View when you place your drawing views
  3. Or edit the drawing views and select the appropriate Design Rep View.
  4. Click the link icon in the drawing view tool so that the drawing view will update when you change your assembly view reps.
You can filter a parts list by the assembly design view rep too.
Brilliant, I guessed there would already be something there for such a
simple thing.
Much appreciated
inv.ideareview
@Anonymous, if the existing workflow works fine for you, I will archive this idea. Does it work fine for you?
Yes, many thanks
inv.ideareview
Status changed to: Archived
Based on the comments from the author of idea, archive this idea.
