Surface development
Surface development
Generate flat pattern of surfaces with compound curvature.
Applicable to any sheet material.
22 Comments
this feature is search by an sheet metal industry,, they want to know when they design a cap of lamp what thickness are best so they don't need to trial and get some error ,,
i ever see it in SW maybe inventor can add this feature to solve the problem in sheet metal industry
thanks
muchlis
Application Engineer
PT Sarana Solusindo Informatika
Indonesia
stevec781
Ability to flatten non developable surface/parts and show strain plot
Tags (2)
pcrawley
Absolutely needed.  Even if the results contain a % error allowance for material behaviour.
jletcher
No they just need to finish buying SPI instead of renting a section of it for unfolding..
http://sheetmetalinventor.com/en/202/spi_sheetmetal_inventor_
andrew
SPI looks a nice tool for unrolling plate. It does not appear to address shell expansion.
http://www.ssi-corporate.com/product-services/products/hull
dan_szymanski
Status changed to: Accepted
Accepted idea [676]. Thanks!
scottmoyse
This has just been added to SolidWorks 2015... just to add a bit more pressure to get it into Inventor.
yes surface development in inventor would be extremely helpfull!!
also once plate is developed it would be helpfull to get a plot of strain over the surface to check how easy it would be to develop/ if the plate needs to be subdivided.
gavbath
This would be a great enhancement. I wonder if the ExactFlat guys would be keen to be acquired.
dan_szymanski
Idea Accepted as [676].  Thanks!
dan_szymanski
Idea added to backlog for future consideration [676]. Thanks!
dan_szymanski
Aadithya01
Hey Guys,
It would be good if the flatten surface feature is brought into Inventor . Already our competitors are having it for a long time eg: Solidworks ...
Please look at the below image
inv.ideareview
Status changed to: Archived
dan_szymanski
dan_szymanski
andrew_faix
Thanks to everyone that contributed to this conversation so far.  We are having some more detailed-level discussions on this topic under NDA on the Inventor Beta Forums.  If you'd like to participate, please visit:
https://bit.ly/InventorBeta
dan_szymanski
This idea has been implemented within Autodesk Inventor 2020. A new Unwrap command allows you to obtain a flat surface from any set of continuous faces. Unwrap lets you flatten nearly any shape into a surface that can be saved or exported in different formats. Special thanks to everyone who cast a vote for it.
nrosati
@dan_szymanski Are there any plans to show the strain plot or be able to see what the calculated strain is for the generated surface?
