Currently, Autodesk Nesting optimizes the parts of a nest based only on a single sheet format per nesting run.
I would like the option to nest a complete assembly simultaneously across two different sheet formats (for example, large and small formats).
The nesting algorithm should automatically decide which parts are placed on large sheets and which on smaller sheets, in order to achieve the best possible material utilization and manufacturing efficiency.
Advantages:
Example:
An assembly contains:
Instead of having to create several separate nests, Autodesk Nesting should analyze the complete assembly and automatically distribute the parts across the available sheet formats to maximize overall material utilization.
