Show only
Search instead for
it would be good if the split operation, in the solid cut option, could admit faces in split tool. in this way you avoid having to create the surface to cut the solid with it
When I want to cut a solid, with a face of geometry, the surface must be created (or a plane on the face if the face is flat) and then cut it. The surface can be made with thicken offset with a distance in 0 mm by selecting the face. I would like it to be able to support geometry face, at least flat, so I should not create planes and surfaces. Regards!!
yes, sometimes I want to cut with one face of another solid, or of the same solid, and I can not do it, and the function if it allows for example to use as a cutting tool a sketch, a surface, or a plane, but not a face, at least I could not do it
FYI, there's a duplicate (actually the original) of this idea that you can vote for: Split command. It already has several votes, so you can add yours and help move it up the chain.
I've asked the moderators to merge this idea into that one. I also asked them to rename it to something easier to find.
