Multiple Measurements
While using the Measure tool in Inventor, it is often that I would like to compare measurements.  It would be great to be able to have multiple measurements on the screen at the same time.  This would be useful for comparing part lengths, comparing cable routing options etc..
Thank you,
Stephen R.
3 Comments
MrSmithtastic
I still think I'd rather they just rolled back to the old measure tool. It was so much simpler to get the desired result!
I really started liking the new measure command when I figured out with only 2 inputs, the rest of the measured results the measure command shows can be clicked on to show them on the screen.  Not intuitive, but really nice.
In addition to multiple measurements at one time, it would be a great improvement if the measured result(s)  could be dragged on the screen to be put into a better viewing position.  Sometimes when you measure within an assembly, the result gets placed at a vertex, which is not where you were needing the measured result to be shown.
