Allow position representation inventor with pattern occurrences. Seems like a simple suggestion, but why can i not have access to the occurrence position in a sketch driven pattern ( though i know that is complex programming) or better yet allow it to rotate like circular pattern does. Also why can i not use points instead of creating a solid to pattern from a separate part! (i.e. create a skeleton part that drives the shape i need to pattern to i have to make solids and cut them away after creating the pattern instead of using the sketch or even points.)
