Show children only should hide patterns
When you select show children only for a display preference in the the model browser it hides all the components in sub assemblies, but it leaves all the component patterns.  I think this should hide everything underneath an assembly except maybe work features.
4 Comments
SteveMDennis
Status changed to: Gathering Support
Actually this sounds like a bug Andrew. When I did Show Children Only (probably R2?) patterns didn't exist... it should NOT show anything below the instances of the edit target.
andrewiv
I just updated to 2020.2 and this is still not behaving as I would expect.  In the screenshot below you can see that I have the show children only option checked but it is still showing the patterns underneath sub-assembly 543421:1.
dan_szymanski
Status changed to: Accepted
Accepted idea/issue [37067] Thanks!
dan_szymanski
This idea has been implemented within Autodesk Inventor 2021.1. Special thanks to everyone who cast a vote for it.
Technology Administrators
