sheet metal flat pattern export via API
With Inventor 2023 there is a new feature called Mark.
The format string option inside the DataIO-Method "WriteDataToFile" offers no possibility to influence the mark layers while exporting the Flat Pattern DXF via API.
First of all, it would be very helpfull to add that possibility. And no, it's not possible with the style editor, because you cannot disable particular layers.
The better way would be enabling the support to use the UI-INI file as an option for the flat pattern dxf export command in the UI instead of creating a string-Format option:
API Sample could be changed to something like this:
Public Sub WriteSheetMetalDXF()
    ' Get the active document.  This assumes it is a part document.
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Get the DataIO object.
    Dim oDataIO As DataIO
    Set oDataIO = oDoc.ComponentDefinition.DataIO
    ' Build the string that defines the format of the DXF file.
    Dim sOut As String
    sOut = "FLAT PATTERN DXF?AcadVersion=R12&OuterProfileLayer=Outer&TrimCenterlinesAtContour=True"
' refer to the INI-File for DXF-Flat Pattern Tranlsation
Dim sIniFile as String
sIniFile = "C:\TEMP\flatPatternDxf.ini" ' Create the DXF file. oDataIO.WriteDataToFile sIniFile, "C:\temp\flat2.dxf" End Sub
2 Comments
Yijiang.Cai
Status changed to: Accepted
Many thanks for posting the idea, and tracked as [INVGEN-69434]
Yijiang.Cai
It has been implemented in API of Inventor 2025, and please have a try. Many thanks!
Technology Administrators
