Sheet metal Flange command automatically trim inner corner
Hi
I would like Auto trim (Crop) when Flange command in inner corner my models
exam:
When use  flange Command in  internal edge Two bend intersection, occurs error "Two plates are interfering" 🙂
Because Two plate is overlap but we wish if we could use corner edit as outer edge when use flange command It would be suitable for production
when flat pattern this model occurs error and plates is interfering
We have inventor 2016. We edit this corner manually by corner chamfer
and it can be flat pattern
I wish this process automatically
Gökhan Kaya
12 Comments
inv.ideareview
Status changed to: Archived
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so.
JCrilly
This needs to be re-opened in my opinion. Inventor is unable to create what I need using its tools. The current solution is cumbersome and imprecise.
After chamfering the corners, I need to play around with the flange offsets to make symmetrical, then edit the flat pattern to get what I actually need. (bottom left is what Inventor creates - bottom right is what is needed)
I am not using the latest version, so if this has already been addressed I haven't seen it.
tyas.swinnen
This would be extremely useful!
This is indeed extremely useful!
The idea should be raised again. You have my support.
Hi.
Let us get this, Please
Running into this issue too, can't believe that this feature isn't present, I blamed myself for being stupid as I couldn't find that option.
nathan.hallQMP6S
I am stunned this isn't a feature yet. Autodesk, please open this issue back up and add it. It's pretty cumbersome currently and it's embarrassing this isn't a feature in Inventor yet.
GJackson-GMC
Wow, i an working for a new sheet metal company and we do a lot off mitred internal flanges. I can not believe this feature is not present within Inventor Spent a good hour messing around before googling, on to fine it can not be done automatically, come on Autodesk get this sorted.
Is it still missing?
jussi_peltola
And still missing..?!
nick_panzarino
this should absolutely be added. still having the same issue in 2024
Yijiang.Cai
Many thanks for providing the comments & ideas continuously, and tracked as [INVGEN-77246].
