Sheet Metal - direct manipulation support
I would like to be able to stretch (modify) flange lenghts by using a 3D direct manipulation arrow.
15 Comments
jletcher
Use Fusion it does this.
MattH_Work
Doesn't fusion do this via 'move face'. Inventor also does it the same way but both fall over when the flange  AND bend need to move.
 I'de like to see flanges, hems etc being added to the edge select options (currently Fillet & Chamfer) so that I just need to click an edge and drag to produce the relevent feature, rather than start command, pick edge, return to dialog , fill in values ....
Lok on youtube at how the competition does it, very swish
BryanKelley
This is something that the team has brought up in the past
dan_szymanski
This project [49692] is under review by the development team.
dan_szymanski
Status changed to: Accepted
Accepted idea [49692]. Thanks!
In the sheet metal module, I would like to have a mouse drag arrow, to adjust flange lengths.
Similar to those used in the part extrusion command.
Brgds,
Chris
Soriani
Vey nice idea
the interface of this module is very old style
Solidwork able the user to be very quickly during the design of a sheet metal part
http://www.youtube.com/watch?v=VKej5gqcH1U
you can see this video to show this capability
paul
Awesome Idea
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
dan_szymanski
dan_szymanski
paul
Not only the Length, all the parameters.
dan_szymanski
This idea has been implemented within Autodesk Inventor 2025. Please review the Inventor 2025 What's New article here, for more information regarding the new in canvas direct manipulation arrows available in the sheet metal flange command. Special thanks to everyone who cast a vote for it.
matthew2DYMM
Observer
Now we need steering wheel like solid edge and fusion.
