Selecting components and features
At present, in order to select feature or component that is hidden below other features or components we have to use "Select other ..." command and go through list of available selection. If we could use ALT key + mouse Rick-click to go through available selection list while features or components are pre-highlighted (to give a visual help what is going to be selected) the whole process would be much faster.
5 Comments
j.romo
Or leave it the way it was In previous versions with the Arrows would be great.
Arrows can be added back as well as leaving the list.
Let's say, we want to take a measurement between two surfaces which are hidden. We will hoover over that area and first visible surface will get highlighted. By using Alt+Right click we will initiate "Select other ..." command and we will go through every surface that is below mouse position. When we get to the right surface we will use left click to select it. This does not require any additional mouse movement nor looking at the list.
2 votes and counting ...
