Select Other more Info needed
So when using select other you get the follow for example
2018-05-29 15_25_22-Autodesk Inventor Professional 2018 - [15174 CAP RIB SKELETON ANGLE-F5.ipt].jpg
this is unbelievably unhelpful
instead it should provide more info as follows
2018-05-29 15_25_22-Autodesk Inventor Professional 2018 - [15174 CAP RIB SKELETON ANGLE-F5.ipt]2.jpg
so it would tell you the line type and which sketch it is from.
Currently I cant tell so I have to turn sketches off to be sure but then normally turning sketches on and off in a sketch does not work so exit turn off sketch renter sketch project finish sketch turn sketch back on. Not a very intelligent way of working.
3 Comments
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-49269].
Yijiang.Cai
Status changed to: Accepted
dan_szymanski
This idea has been implemented within Autodesk Inventor 2023.2. Please review the Inventor 2023.2 What's New article here, for more information regarding how sketch workflows have been enhanced. Special thanks to everyone who cast a vote for it.
