SAVE SECTION VIEW
SAVE SECTION VIEW
I am using Solid edge and Autodesk inventor both software, In Solid edge you can save section view and cut multiple section at a time on different plane or direction and also it can use in drafting while calling view, I attached solid edge section view photos how it works, Is there any way for saving section view in inventor.
2 Comments
Paul-Mason
You can achieve similar results by using the BREAK OUT on the PLACE VIEW menu
WCrihfield
Yes, we can 'save' section views in Inventor.  But only in the 'model' environment (part or assembly model file), and only when you have a custom view representation available & active in the model at that time.  Unfortunately, the section view defined in the view representation on the model side, does not carry over into a drawing view in a drawing.  That one added bit of functionality has been asked for by many different people (including myself) for many years now.  So, there are likely several other similar sounding posts within the 'Inventor Ideas' forum area, wanting essentially the same thing.  It may be advantageous to have an Autodesk moderator attempt to 'Link' or 'combine' some of them together, to get more votes applied to them as a whole.
To Work with Section Views
Section View Enhancements
About View Representations
