This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Replace Punch (iFeature replace)
This idea is simple. Select a Punch feature on a sheet metal part and Right Click and give us the ability to replace the punch with a different .ide file.
Think of it being like the tool in Assembly files, Replace Component. Except it's for iFeatures (Punches) in Sheet Metal.
Currently if you place a punch feature and later have to come back to it and change it beyond the built-in parameters used to make it, then you have to delete the punch (keep the original sketch) and then place a new punch. This is less than ideal b/c if you have a iPart family, the feature will not update automatically. If the punch is simply a set of holes and I updated the original punch.ide to have a wider spacing and nothing else. Then the current method of replacement will break all assembly constraints too. The suggested idea could be a big improvement to not break all constraints. Because it'll act like a Component Replace. With a Component Replace, any constraint applied will stay if the new part is made of the same elements/feature/order of the original file being replaced. This idea would follow the same concept.
I personally can see this being a headliner upgrade to Inventor on the next release.
This Idea is related to these threads:
9 Comments
Uwe_Lindner
English Translation (per Google Translate):
I want a way to replace an inserted iFeature into a model by another iFeature.
Request comes from the sheet metal environment where the insert you need an insertion point and this is required for each punch feature.
Kunden suchen nach einer Möglichkeit wie man ein in ein Modell eingefügtes iFeature durch ein anderes ifeature ersetzen kann.
Anforderung kommt als erstes aus dem Blechbereich wo man zum einfügen einen Einfügepunkt benötigt und dieser für jedes Stanzfeature benötigt wird.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
holgerb-mardmoeller
I've got a call from a customer who has the same issue with his ifeatures in old sheet metall parts. There is no way to change the path of the ide or the ide-file. It was an old part from 2010 and it wasn't able to change anything, no angle no value. A replace function could sove this problem.
wayne.helleyY67EK
I would really like this feature right now, or at least the option to break up a previously placed iFeature into standard features
Hunteil
Here's a link to this Idea to allow us to Replace Punch just like the Replace Component Tool: https://forums.autodesk.com/t5/inventor-ideas/replace-punch-ifeature-replace/idi-p/12237740
I figured creating a new idea post w/more information could be helpful.
nbossardKratos
Observer
This has to be, for sheet metal and copper bus design, one of the worst parts of using Inventor.  Sure, the punch tool is useful, but if it ever needs changing, the process, including losing mates, will make you wish you just used sketch geometry to begin with.
Uwe_Lindner
Yijiang.Cai
Status changed to: Accepted
Accepted as [INVGEN-63370]
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
