Reorder Blocks in browser
Requesting the possibility to reorder imported Autocad blocks in Inventor browser.
When many blocks are imported it is not easy to manage them.
10 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
Curios as to why this was archived?  This is a viable and legitimate question.  These Blocks in question do not share properties.  They do not build upon each other in a normal browser setting.  Why would you not be able to re-order the blocks?  Our company uses a standard part template that has blocks pre-loaded and ready to drop and utilize in sketches.  To ask a company to create these blocks in order such as size for structural steel or a multitude of other required theories is insane.
I conquer that these should be able to be sorted in any fashion required by the user.  I'm curious as to why this would not be a standard function in the beginning.
william
i would like to vote for this idea as well. I think it is a sensible practical suggestion.
@inv.ideareview  can we un-archive this?
dan_szymanski
Status changed to: Gathering Support
@william , Reset to Gathering Support per your request.  I also like this idea.  😉 -Dan
kimK7B54
There are several request for this under different verbiage.   Perhaps if they were combined there would be sufficient motivation for Autodesk to implement this.  It has come up repeatedly since well before 2016.  It can't very well gather support if it keeps getting archived.
xenocatalyst
I also have a need to be able to reorder sketch blocks and autocad blocks in the browser.
dan_szymanski
Idea added to backlog for future consideration [52622]. Thanks!
dan_szymanski
Status changed to: Accepted
Accepted idea [52622]. Thanks!
dan_szymanski
This idea has been implemented within Autodesk Inventor 2022.2. Please review the Inventor 2022.2 What's New article here, for more information regarding how you may leverage it. Special thanks to everyone who cast a vote for it.
