Changes are part of the design engineer's everyday life and should be as simple as possible. Here are some ideas on how to improve the usability of MBD:
- Change tolerance feature with more than one segment
Only the last segment can be edited:
If two or three segments are added, then it is not possible to edit the first segment. The value already but not the segment (shape or position symbol). - It would be nice if all the 3D annotations would rotate in the current view.
Currently, the symbols cannot be read optimally, the 3D model must be rotated in space to make all symbols recognizable. This applies in particular to diameter dimensions in side view. - If we think about the downstream use of diameter dimensions, it would be helpful if they could be used in the top and side view of the drawing.
