Pattern/Mirror feature(s) using adjust and new solid option together
Hi All,
Sometimes it should be great if I could create new solid/surface bodies with pattern/mirror when I select a feature using adjust options.
Here is a simple example. Currently it's really circumstantial to create like this:
Now if  I pattern feature I cant select new solid:
Missing new solid option
My idea is something like this:
Best regards,
Attila Farkas
3 Comments
dan_szymanski
Status changed to: Duplicate
This Idea is a duplicate of the Master Idea located here:
http://forums.autodesk.com/t5/inventor-ideastation/pattern-mirror-more-solid-or-surface-body-in-one-...
Please be sure to cast your kudo to the Master Ideas as to not split the votes.  Thanks! -Dan
AttilaFarkas
Hi Dan,
This is not a duplicate idea, the other idea is also mine [edited by moderator - removed content due to beta NDA]
So my idea is:
It should be a great possibility if a new solid option could be selected during feature pattern. In this case users could combine the adjust solution with multisolid pattern.
On the attached pictures you can see a sample for this situation:
If I want to create this modell as a multibody part then its circumstantial now and it will be the same in 2016.
The easiest way could be to pattern the cylindrical extrusion using the adjust option but separate the result to new bodies.
Its something like iCopy in the assembly environment.
Could you please change the status back to new idea or to accepted 🙂
Best regards,
Attila Farkas
dan_szymanski
Status changed to: Gathering Support
