Parameter Precision in Drawing Notes
When calling out parameter values in a note you always need to manually set the precision. And trailing zeros are never suppressed. That brings a lot of work if values are changing, you have to check all the notes.
Can’t we set the precision globally in a style? Or use the precision set in the dimension style? And of course, suppress zeros.
