Outside border (shape) on dimensions text
I need several time to create dimensions with a rectangle outside the text (shape) that indicate it is a reference.
See attach example.
Olivier
2 Comments
Usually reference dimensions are specified by using parentheses around it, which can be selected in the precision and tolerance tab when editing the dimension as a tolerance method.
If you want the square, in the same place is the basic option.  That puts a square around the dim.image.pngimage.png
o-fischer
Thanks, it's exactelly what i need. Sorry but i didn't know this functionnality.
