Open idw directly from part list.
Hi!
I often work with assemblies that contains many sub-assemblies (weldments etc.), wich need their own idws.
In that case it would be very helpful to be able to access the idw directly from the main assemblys part list.
The open function that exist now is good, but many times its unnecessary to open the .iam before open the .idw .
Adding Vault bracket to RMB on part in partlist would be sweet 🙂
Even
4 Comments
tyas.swinnen
@Eikaas_Even This exactly what needs to be added tot the partslist/BOM!
Right now I've added a short-key to the 'open drawing'-command and if I need to access a drawing, I use the search function in the model tree of the master assembly and select the part/assembly and open the drawing with the designated short-key.
A needed extra is the 'check-in' from the BOM, right now we can only 'check-out' in the BOM.
I fully support your cause! 😉
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-85634]
dan_szymanski
Status changed to: Accepted
Accepted idea [INVGEN-85634]. Thanks!
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2027.1. Please review the Inventor 2027.1 What's New article here. For more information regarding how you may leverage the feature, and please review this page. Special thanks to everyone who cast a vote for it.
