New button - 4 points inserted at once
New button in sketch mode to insert 4 points at once. The points should be horizontally and vertically aligned and have a vertical and horizontal dimension.
If you use this button you can insert 4 points already aligned. You can then change dimensions, add new dimensions, and make holes quickly if you don't like using hole patterns.
1 Comment
mikeh4
Possible work around. Draw a rectangle and make it construction geometry.  Horizontal and vertical alignment is there but, still have to add dimensions, and you can use those corners for center point of a hole.
Regards.
