Need Help
Need Help
Hello i have Autodesk Inventor. I recieved an email of a Autodesk drawing in Pdf format. The drawing is lacking information needed, is there a way the drawing can be viewed from my email to aquire measurements?? If so how? Is there a way I can edit the drawing?
1 Comment
The pdf file is not editable. This is the nature of things - the pdf format is used to transmit content, not to work on the content.
The pdf file contains the information that the author wanted to give you.
If you need to change something in the content, you need to edit the source file.
Send your comments to the author of the drawing or ask him to provide the source files.
