Make Instance Properties accessible through API
Instance Properties are a great functionality to distinguish between instances in an assembly since version 2022.
To me it would be very helpful, if you could create and set instance properties through the API.
This is currently not supported, since the BOMRow.OccurrencePropertySets-Property is only provided as a read-only Property.
A write-access would be very much appreciated to programmatically store instance-properties in an assembly.
