Multiple Mid Planes
Multiple Mid Planes
When making a mid plane between two planes, I think it would be a great idea to have a drop down to insert more than one mid plane equally spaced.
3 Comments
ed_heathcote
Observer
I think that would be really helpful as it is a real pain when you need to evenly space multiple components if you want to have say 2 brackets evenly split between two faces
AndrewWiorek
If you know the distance between the 2 end planes with a parameter or dimension, you can just use a fitted pattern to do this.
jimm_motyka_777
What if this was a midplane array?  Choose your outer most planes and then have it calculate multiple planes between those, much in the way that the array command works.  It would evenly space planes based on the number of planes required between the two outer most ones.  I could see this being very helpful in our designs.
