Show only
Search instead for
I think that would be really helpful as it is a real pain when you need to evenly space multiple components if you want to have say 2 brackets evenly split between two faces
What if this was a midplane array? Choose your outer most planes and then have it calculate multiple planes between those, much in the way that the array command works. It would evenly space planes based on the number of planes required between the two outer most ones. I could see this being very helpful in our designs.
