It is usually recommended that bigger assemblies are initially constructed in a skeleton part, in which all the bodies are drawn and fitted to one another. They are then extracted into an assembly using the Make Components feature.
However, this method is not practical when constructing assemblies using Sheet Metal of varying thicknesses, since only one thickness is allowed in the Sheet Metal Defaults option dialog. Therefore I wish that it is possible to work with multiple sheet metal thicknesses in the same part.
