Multi-value parameter sort order
Add support to list numerical multi-value parameters numerically instead of alphabetically.
Add following multi-values:
  • 50 mm
  • 75 mm
  • 100 mm
Resulting sort order is:
  • 100 mm
  • 50 mm
  • 75 mm
Preferred sort order would be in ascending numerical order. Option to choose sort order could be a benefit to some users.
I know there is a post for adding sorting support in iLogic forms, but this request is for basic Inventor.
Jerry
9 Comments
JBerns
Found an iLogic solution to sort the MultiValue parameters:
  1.  Create a MultiValue parameter.
  2.  Create a new iLogic rule.
  3.  Paste this code and then modify the parameter name and the list.
MultiValue.SetList("Length", "50 mm", "75 mm", "100 mm")
  4. Save and Run the rule.
  5. The parameter will now display in the order set in the iLogic code.
You can suppress or delete the iLogic rule, but you may wish to maintain it in case new parameter sizes are required.
Hope this is helpful.
Jerry
dusan.naus.trz
Parameter Sort and up and down arrow. Please see the pictures. If you like Idea, then vote.
Genicee
The ability to rearrange parameters would be a welcome improvement.
petr_vonasek
Not only rearrange parameters in the list but also the ability to rearrange rows in the Parameter table would be appreciated. As I gradually build a model I am adding new user parameters and finally they requires rearrangement to keep them in order from the most important in the first row.
dan_szymanski
Status changed to: Accepted
Accepted idea [50570]. Thanks!
Yijiang.Cai
This idea has been implemented within Autodesk Inventor 2023. Please review the Inventor 2023 What's New article here. For more information regarding how you may leverage the feature, please review this page. Special thanks to everyone who cast a vote for it.
dusan.naus.trz
dusan.naus.trz
dusan.naus.trz
