I find it strange that when creating a section you need to edit the obtained view in order to change some of the properties found in Display Options and others are in the right click menu of the section line.
There is a similar post: https://forums.autodesk.com/t5/inventor-ideas/drawing-view-redesign/idi-p/9029019
Add those option in the default section creation dialogue (cut inheritance, alignment to view, orientation, etc.) and also add the possibility to hide the preview and choose the section orientation from the menu.
I work with large assemblies and generation of the preview takes a lot of time. 95% of the cases I already know how the section will look like, I need to make it and not crash.
Also, let's say I make a new section, by default its name is A, I rename it to something else, next section will be, by default, B. Please make it so it will keep the alphabetical order intact if a section, upon creation, has a different name. It would save a lot of time.
