Modification of commands in the Parameter Table - "Userdefined Parameters" - Shortcut for new parameter
Hi from Vienna, Austria!
I think, You will agree: It's a nerving process, when You want to create a couple of new "User Defined Parameters" in the parameter table!
When ever You want to go to the next line to create a new parameter You have to select "Add Numeric" with the mouse.
As Your hands are on the Keyboard writing the name, the workflow is interrupted by this mouse action!
I prefer to create the Parameters by name first. For me it is not important to set the values during the "creation work flow".
The accurate values will be set later during design process - especially when You use "derived components" with Parameter Parts
Why is there no "Shortkey" like a defined Key on the keybord? (ALT+..., or a simple Key like "," ...)
Do You remember AutoCAD? When You create(d) new layers the Comma "," jumps to the next line to create the next one. I Know the origin of this comes from the DOS commandline commando, but it is still working!
Something like This would be great.
Have a nice weekend, stay save
Carolus Stigler
1 Comment
DRoam
