Mirror assembly improvements - append symetric constraint option
I would lik to se a funktion in mirror assambly that uses added mirror constrains to the komponents. If i change the length of the table now i have to do the mirror again.
27 Comments
The function Symetry in the assembly should use the symetrie constraints for all assemblys and parts selected through the fonction.Simetry for Assembly.jpg
I realise this has come up time and time again, so am at a loss as to why it has never been fixed; please, for the love of god, fix the mirror component tool!
It is absolutely useless as it is now - with the mirrored part free to float around in space.
The part needs to be fixed/constrained about the mirror plane, which would allow it to update/move to suit, if the assembly changes.
Stop fluffing around with moving buttons, base view tools etc Autodesk, and get the fundamentals right first!
Regards Glen.
DRoam
@Anonymous and others: There is an identical request that's already received a good deal of support located here:
Treat "Mirror" in an assembly like a pattern (maintain symmetry)
Please cast a Kudo for it as well so as not to split and water down votes between ideas.
dan_szymanski
Status changed to: Accepted
Accepted idea [530]. Thanks!
dan_szymanski
Idea added to backlog for future consideration [530]. Thanks!
RStancescu
any updates on this in 2020?
didier.spinnewyn
In its current configuration, the symmetry command is useless.
