取消
显示结果
显示  仅  | 搜索替代
您的意思是:
Mirror assembly improvements - append symetric constraint option
I would lik to se a funktion in mirror assambly that uses added mirror constrains to the komponents. If i change the length of the table now i have to do the mirror again.
27 条评论
不适用
The function Symetry in the assembly should use the symetrie constraints for all assemblys and parts selected through the fonction.Simetry for Assembly.jpg
不适用
I realise this has come up time and time again, so am at a loss as to why it has never been fixed; please, for the love of god, fix the mirror component tool!
It is absolutely useless as it is now - with the mirrored part free to float around in space.
The part needs to be fixed/constrained about the mirror plane, which would allow it to update/move to suit, if the assembly changes.
Stop fluffing around with moving buttons, base view tools etc Autodesk, and get the fundamentals right first!
Regards Glen.
DRoam
@Anonymous and others: There is an identical request that's already received a good deal of support located here:
Treat "Mirror" in an assembly like a pattern (maintain symmetry)
Please cast a Kudo for it as well so as not to split and water down votes between ideas.
dan_szymanski
状态已更改为: Accepted
Accepted idea [530]. Thanks!
dan_szymanski
状态已更改为: Future Consideration
Idea added to backlog for future consideration [530]. Thanks!
RStancescu
any updates on this in 2020?
didier.spinnewyn
In its current configuration, the symmetry command is useless.
找不到想要的内容?向社区提问或分享您的知识。
提交想法
