MAKE 'EXPORT FACE' WORK FROM AN iPART MEMBER FILE
Why does 'export face' not work on flat patterns of iPart members??  I mean, it clearly works, all the way up to the point where you hit OK after tyoing the filename to save it as.  If the sheet metal iPart member can be unfolded, and the command can be run, and even gets all the way thru the save-as dialog...  why not make it actually work?  We use lots of sheet metal iParts, and every time I need to send one out to the plasma cutter, I have to save the part as a bunk temp file, delete the table to make it a normal part, and then do the 'export face' command from the temp part.  Im sure this is a bug, and not a purposeful limitation.  It negates alot of the benefit we would otherwise gain from the use of iParts. 😞
1 Comment
inv.ideareview
Status changed to: Archived
Thanks for sharing your Idea. The product team continually reviews this forum aiming to deliver in the most impactful way we can based on voting. We also regularly examine the list to make sure it reflects the most current Ideas. As part of this process we archive old Ideas that haven’t received broad support. This ensures there is room for new Ideas to be reviewed by the community and for the most relevant and meaningful ones to gain votes.
This Idea is archived because it's been on the board for over a year and hasn't received many votes. If you want to raise it again and try to gain more support across the community, you're welcome to do so. Leveraging images, animated gifs or sample mock-ups can help convey concepts and generate more votes from other users. If you have questions or see a connection between this Idea and others that should be accounted for, please let us know.
 - INV.IdeaReview
