Locking Custom Parameters & Re-Order Parameters
At my company we have been utilizing iPart & iAssembly Factories in order to create custom templates and standards to more or less automate our design process and to push corrections and modifications through all affected files by changing it's parameter in a single custom base file.  What we would like to be able to do is to be able to lock certain parameters even if it were only done by checking an option box, to help prevent certain data values from being changed by accident, without having to create specific iLogic Rules to Notify the user that those parameters were created as "standards" and should not be edited without Administrator approval.  Another thought would be to have some sort of management option, similar to vault permisions, where only certain users could modify certain data values.
Also it would be very helpful if users were able to reorder and move parameters around to help group parameters together without having to redo the parameters from scratch or via an xml file everytime.  If it were possible to create groups which could be assigned to parameters, similar to the filter, that could be very useful as well.
Thank You
4 Comments
petestrycharske
There is an older post that has this idea in it, so please vote for that one as well.  Hope all is well and have a most blessed day!
http://forums.autodesk.com/t5/inventor-ideastation/parameters-dialog-overhaul/idi-p/4774867
Peace,
Pete
ulasdeniz
I think reordering is a must. parameter editor needs to be more flexible. thanks
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
