Limits & Fits Imporvement
Using the limits and fits in Inventor is a great tool, however it throws up some problems when trying to use it when trying to export it for CAM and creating drawings.
at the minute if we want the model to be at the median value for CAM purposes (say we want an H7 on a 30mm hole, this will put the model to 30.011mm). When we come to create a drawing of the part however, the dimension will be displayed as 30.011mm and when we tolerance that with an H7 it will show the tolerance as 30.036 - 30.011mm, which would be wrong.
Idea: To create a way to keep the model dimension at the median value (for CAM), but have the drawing represent the dimension at the nominal value.
1 Comment
david.tunnard
See post that led to the idea...
Limits & Fits post
