ISO 2768 Default Tolerance in .ipt
Currently the Default Tolerance is pretty much a standard for just ANSI, for drawings that are DIN ISO we use ISO 2768, if possible being able to extract all the dimensions in a .idw to an excel spreadsheet with the tolerances would help with first inspection reports.
1 Comment
Ronald_Moore
I would love to see this type of Tolerance implemented in Autodesk products. From my understanding this is the standard followed in European countries. The standard bases tolerance on the size of the dimension rather than the number of digits. This makes so much sense as the tolerance increases with the size of the part.
We use this standard globally and it would be great to apply it as a default tolerance on the document settings of ipt files.
Here is how we show this on our drawing title blocks.
