Sheet Metal's dimension limits
The sheet metal panels is cut from sheets of commercial dimension. (in exemple 1500x3600mm)
Insert in the sheet metal' default values two new values fields for the Maximum length and width of the native panel.
If the sheet metal is cut from metal Coils, only one measure is requested.
When the opened sheet metal has one measure (or both two) greater then the native panel measures, the system give an error.
thanx
Alessandro
12 Comments
ThomasSwanson
I have had multiple customer request for the ability to change stock number for different sheet metal rules.
User set  up sheet metal rules for many different metal types/thickness that cover a range of stock numbers.  It would be nice to have a stock number field in the rule dialog box, much like the materials,  so that a different stock number can be entered that will push to the iproperties when selected.
Tags (5)
ThomasSwanson
ejmacchi
Sheet metal rules allow you to build a library of sheet materials that match your materials available in stock. The raw materials have their own properties, such as cost, a particular stock number, etc. It would be nice to be able to store iProperty overrides in the sheet metal rules, so that these properties are automatically filled out by selecting the sheet metal rule in a part.
Example: you have a sheet metal rule for 0,5mm 1.4301 Steel. That material gets stored under its own stock number at a particular storage location, and has a cost $XX/m2. By selecting the rule for "0,5mm 1.4301" the Stock Number and Estimated Cost iProperties, and Storage_Location custom property are automatically filled out. These values would come from additional fields in the sheet metal rule.
Tags (3)
ejmacchi
Example of how it could look:
jtylerbc
Seems like this could be done now with some fairly simple iLogic work.  It might be as simple as adding a few User Parameters, and a rule to check the material dimensions agains the sheet metal extents of the part (and warn the user if the limits are violated).
ic198
If you right-click on 'Flat Pattern' in the browser there is an option for 'Extents' which displays the length, width and sheet extent area of the flat pattern. Not quite what you are looking for but it is very useful, a very quick way to check parts you think might be too large.
ejmacchi
I have exactly the same problem. We want to compare the part size to the maximum usable sheet size. Instead of having just those two fields, I had an idea for a more generalized solution where the active SM rule could override any number of iProperties:
http://forums.autodesk.com/t5/inventor-ideas/iproperty-overrides-from-sheet-metal-rule/idi-p/5641555
Currently we have implemented a solution with iLogic, exactly as described by jtylerbc, but this is far more complex than it seams, especially if you want it to be scalable. The result is a solution that is incredibly difficult to maintain. Having the ability to control this information from the SM rule would be more flexible and easier to manage.
rob_bolter
Totally agree, was about to submit this myself. I made a ribbon plugin to do this for my company.
ThomasSwanson
I did it with two illogic codes, or maybe it was one.   Anyway, it was a huge case statement that looks up the name of the sheetmetal style and then applies the correct stock number to the iproperty on save.   It works but you have to make certain that both the sheet metal rule and the name in the case statement are spelled exactly the same or it will not find it.   Not to mention I have to edit it every time they add another sheet metal style to Inventor.
rob_bolter
I did similar using a plugin I wrote to go on the ribbon. Mine looks through an XML file and selects a sheet that best matches the components size. It just seems like such a fundamental thing to be missing from Inventor, especially Sheet Metal parts.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
