Show only
Search instead for
In the new drilling dialog it is no longer possible to select the endpoints of a sketch with a window. If possible, reintroduce the function into the drilling dialog.
This is being resolved for an upcoming release as issue 16116; it can be tested in the current Inventor Alpha build available from the Inventor Feedback project. If you don't have access & would like to apply then you can do so using:
