Inventor 2019 -Concentric Hole From Plane
Could the original Hole creation function be restored as it is known from previous versions?  I attach an explanatory video.
6 Comments
bsidesign
It would be nice to have the option to select a work plane to start the new hole command not just a part face. If nothing else it would be nice be able to select a work plane from the hole command and go directly into the sketch and then put in points, project geometry etc. as needed and then have the new functionality of switching back to the hole command to finish the operation. Really all this does is eliminate the need to create a sketch prior to the hole command which falls into the new hole command workflow, not a combination of old and new.
Tags (1)
JoyceZhou
Thanks for all the feedback. This has been tracked as INVGEN-8642 in the tracking system and Development team is working on it. Will inform you if it's ready to use. Thanks!
inv.ideareview
Status changed to: Accepted
dan_szymanski
Yijiang.Cai
It has been addressed in Inventor 2019.2.
Technology Administrators
