This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Improve Mirrored Parts - Add option to ground mirrored components
This suggestion comes in two parts (to avoid having two separate posts), both related to Mirrored Parts.
1. Can we have a checkbox option in the Mirrored Parts interface to automatically ground the new mirrored part? I've had catastrophic failures of large assemblies because a mirrored part has somehow gotten moved out of place, subsequently having a domino effect, upsetting everything contrained to it or referenced to it. Even now I'm aware of the problem, I don't always remember to manually ground them afterwards. What would be even better would be if the contraints of the original part could be mirrored also, or some sort of positional mirror constraint could be placed between the original and mirrored part, such that any change to the original would accurately be reflected in the mirror version. I've spent hours trying to correct these failures. I've also seen a few posts from others with similar experiences
2. Content Centre and Frame Generator Parts (specifically, steel sections). I often create steel sectional frames and assemblies (sometimes using Frame Generator, sometimes from Content Center parts), which require a symmetrical counterpart. I have tried mirroring the individual parts or complete assembly, but inevitably several parts are mirrored in location but have the same orientation as the original, so I have to create the symmetrical version from scratch. If this could be corrected it would be a big time saver, broadening the usabilty of this function.
Original Title:  Improve Mirrored Parts
15 Comments
Still wondering why after mirroring an object or objects that I have to go back and apply constraints. Doesn't mirroring objects imply that I want them constrained the same as the original objects? I use Inventor 2016, shouldn't this at least be an option at this point? Either mirror the constraints (option 1) or mirrored objects grounded (option 2)...my thoughts for Friday...
jtylerbc
Agreed.  Should have been added when the Symmetry constraint was introduced.  I think the simplest way to make it work would be to automatically add symmetry constraints to the origin planes (about the mirror plane) when the parts are mirrored.
Is this an option in the current Mirror command? If so where is it located
and how is it invoked?
Frank J. Nagle II
Mechanical Engineer
Summit Trailer Sales Inc.
Summit Station, Pa. 17979
570-754-3511 Ext.17
jtylerbc
Frank, I may have been unclear on how I wrote that.  The automatic constraints I referred to do not currently exist.
Didn't think so. I looked at the mirror dialog box pretty thoroughly before
I posted this suggestion. Didn't want to suggest something that already
existed.
Frank J. Nagle II
Mechanical Engineer
570-754-3511 Ext.17
r_lehmann79
I'm also lokking for that option.
There has been an improvement in the 2016 version: when a fixed component is mirrored, then the new instance is also fixed.
Maybe in the next version...?!?
regards
Ralf
DRoam
This has been requested so many times in so many different ways, and Autodesk has still shown no sign of making any changes.
See a similar request here: IdeaStation: Treat "Mirror" in an assembly like a pattern (maintain symmetry)
There's a link someone posted in that thread to a video on how SolidWorks handles mirroring, and it's fantastic. Take a look if you want to be green with envy until Autodesk does something similar: YouTube: Q&A - How do I mirror a component at assembly level in SolidWorks?
Happy New Year to everyone! and thank you all for your votes. maybe Autodesk is listening and will add it to 2017. Hope you all have a great new year and a safe and fun New Years Eve! God bless
I totally agree, and posted a similar suggestion myself last year.
Steve,
I thought I had as well, but couldn't find it. And I certainly didn't
receive such overwhelming support for the suggestion. It just seemed to me
that something like this should have been a part of Inventor from the
beginning. Who knows, maybe Autodesk will finally incorporate this feature
in the next release. Thanks again for your attention in this matter. Kudos
to you as well my friend.
Frank J. Nagle II
Mechanical Engineer
570-754-3511 Ext.17
Let's hope they do. I had some pretty big assembly models fall catastrophically apart before I became aware that the mirrored parts were not automatically constrained.
Steve West
Design Engineer
Alltherm Engineering Ltd
Dudley
UK
dan_szymanski
Status changed to: Accepted
Accepted idea [US-116634]. Thanks!
ChrisMitchell01
This idea has been implemented within Autodesk Inventor 2017R2. Special thanks to everyone who cast a vote for it
jeanie.wayker
Thanks for the reply. I am aware they have now implemented this in 2017.
[Email Signature]
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
