Improve Metric Timning Belt Design Capabilities in Inventor
The Timing Belt design functionality in Autodesk Inventor is currently very limited for metric applications.
In practical mechanical design, I often need to use other software pachages such as MITCalc to property select and design metric timing belts because Inventor soes not provide enough metric belt profiles, standars, and design options.
This is inconvenient because I would prefer to complete the entire mechanical design process directly in Autodesk Inventor instead of switching between different software applications.
I believe the Timing Belt Generator should be expanded to support a much wider range of metric timing belt standars, profiles, tooth pitches, pully specifications, belt selections, and manufacturer data.
For example, better suppport for commonly used metric profiles such as HTD GT, T-series, AT-series, and other industrial metric timing belt profiles would be very useful for mechanical engineers.
Autodesk Inventor is already a powerful mechanical design platform. Improving the metric Timing Belt functionality would allow engineers to complete more of their power transmission design directly inside Inventor and reduce the need for external software.
I strongly recommend expanding and improving the metric Timing Belt design capabilities in Autodesk Inventor.
1 Comment
a_ghadimi1985
 A More Complete Timing Belt Design Workflow Is Needed
The current Timing Belt functinality in Inventor would benefit friom a more comprehensive engineering workflow, especially for metric power transmision applications.
In real-would mechanical design, selecting a timingbelt is not limited to choosing a tooth profile. Engineers need to define and verify parameters such a pitch, tooth profile, belt width, pully tooth count, pitch diameter, center distance, belt length, speed, transmitted power, torque, and allowable tension.
It would be highly valuable if Inventor could provide a more complete darabase and sedign workflow for widely used metric timing belt systems, including HTD, GT, T, AT and other industrial profiles, together with standardized pully and belt dimensions and, where possible, manfacturer-specific data.
Another important improvement would be the ability to calculate and validate the selected belt and pully combination based on power, speed, torque, service conditions and belt length, rather than treating the Timing Belt Generator primarily as a geometric modeling tool.
This would make the feature much more useful for actual mechanical power transmission design and would allow engineers to complete the entire timing belt selection, sizing and modeling process directly within Inventor.
Inventor is already a powerful mechanical design platform. Bringing the Timing belt Generator closer to a complete enginnering design tool would be a significant improvement for professional users.
