The Timing Belt design functionality in Autodesk Inventor is currently very limited for metric applications.
In practical mechanical design, I often need to use other software pachages such as MITCalc to property select and design metric timing belts because Inventor soes not provide enough metric belt profiles, standars, and design options.
This is inconvenient because I would prefer to complete the entire mechanical design process directly in Autodesk Inventor instead of switching between different software applications.
I believe the Timing Belt Generator should be expanded to support a much wider range of metric timing belt standars, profiles, tooth pitches, pully specifications, belt selections, and manufacturer data.
For example, better suppport for commonly used metric profiles such as HTD GT, T-series, AT-series, and other industrial metric timing belt profiles would be very useful for mechanical engineers.
Autodesk Inventor is already a powerful mechanical design platform. Improving the metric Timing Belt functionality would allow engineers to complete more of their power transmission design directly inside Inventor and reduce the need for external software.
I strongly recommend expanding and improving the metric Timing Belt design capabilities in Autodesk Inventor.
