Ilogic Form Enabling Parameter
Problem:
When creating a form you have the option to lock certain parameters in that form under the "Behaviour" section. This makes the chosen parameter dependant on another True or False parameter.
The problem is that the "enabling parameter" has to be "True" to enable the parameter.
Idea:
I feel when choosing your "Enabling Parameter Name" you should also have an option to choose "True" or "False" as the enabling status.
Example:
I use this a lot to give standard parts the option of being "Custom Parts"
If you have a standard item with standard dimensions you can create a True or False parameter called "Standard"
then if the parameter is False then it will enable the parameters in the form which will change this from a standard part to a custom part.
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
