Show only
Search instead for
I would like to associate an ifeature with a part, so when the part is placed in an assembly it will apply the iFeature into selected parts.
For example, if I place a bolt into an assembly, I want an iFeature to place the hole into the matching plate. Or if I have a 6 hole pattern in a part, when I place the part into an assembly it places the matching threaded pattern into another part in the assembly.
I would like to see iFeatures in the Machining environment. Since this is a "special" assembly case, I would like to see it here. My situation is that we have ifeatures for a special hydraulic port that we use. I cant place this ifeature in a machined weldment since this is not available.
This is also something that my division at Parker Hannifin would love to see as now we have to derive the machined .iam and then put our iFeatures in on the derived part. Which just creates an extra part number for us to maintain.
Place an iFeature into multiple parts in an assembly hoser_71 | 11-14-2012 01:40 PM
I too would love to see this functionality. I don't use the frame generator. I keep all my frame comonents as iParts to update thoughout all my assemblies when I make a change to one iPart file. Given that, I miter tubes all the time. It gets tedious mitering 15-20 components each time. I also have punches my company uses so an iFeature for those would be helpful as well.
Why does this move from "Accepted" to "future consideration"? Is it because it has only received a few votes since 2015? Maybe that is because people quit voting for it after it was "accepted". Why should they vote for something that's "accepted"?
The recent status changes of many Ideas from "Accepted" to "Future Consideration" is part of an effort that, we hope, allows for more predictability. The general notion that we are striving for, is to mark ideas that are being considered in the near term as "Accepted" and longer term as "Future Consideration". Noting that both "Accepted" and "Future Consideration" ideas exist within our internal database (product enhancement backlog) as being "on our radar" so to speak. We do not claim the legacy and current Ideas process to be perfect, however we are doing all we can to improve upon it (please understand 5,000+ ideas is quite a bit to manage ). On a side note, I would hope that the status of an Idea would not prevent others from voting on it. I personally would slap a vote on any idea I wanted to see in Inventor, regardless of status. However that is just me. Thanks & regards, -Dan
That is ALOT of request to manage. I applaud you for taking that on. The label "future Consideration" to me seems like it is moved futher down the priority list. Not quite as low of a priority as "archived", but lower than "accepted". From what you are saying, it seems like "Accepted" and Futur Consideration" are on the same level. One is just near term and other is long term.
I really need this feature to work in an assembly. We are a manufacturer of composite swimming pools, and we have a base model, which is an assembly. As the pool is constructed with hardware like lifting brackets and so on.
Now for customers we take that base model and place it into an assembly, in witch we place the required hardware like lamps, nozzles and so on. It's on this level that we want to created the cut-outs, so we can always have an un-effected base model.
Now we need to create the sketch, and extrusions for every item. While some of these will be very client specific, most are not. It would be such a benefit if we could use the iFeature library for our most used cut-outs. And at the moment, it will only work on parts.
We have needed the ability to use iFeatures in assemblies for a very long time. Another similar ability I have always wanted to have in an assembly is SketchBlockDefinitions and SketchBlocks, like we have in Parts. If we could at least save a bunch of those in our assembly, we could readily drop them into our assembly level sketches for all our standard cut extrude features that must be done at the assembly level. Being able to use iFeatures in our assemblies would be the obvious next step along that productivity enhancement ladder.
By the way @dan_szymanski , we can probably bundle this other very similar sounding idea that originated back in 2020 in with this one too. It only has 16 votes as of posting this, but every vote counts towards getting this implemented sooner rather than later (louder shout from more people wanting it).
Since this is very similar to iFeatures I would also want to lump Content Center Features with this to allow both to be used in Assembly/Weldment environments. My team would love to use either iFeatures or Content Center features more often but with a little less than half of our machined components being weldments it makes it not worth investing time in.
