iFeatureにiMateを含められるようにしてほしい
例えば、コネクタの取付穴などサイズや形状が決まっているものは、iFeature で登録する場合があります。
このような穴は取付られる部品も決まっているわけですから、iMateを含めてiFeature 登録できるようにすれば、部品配置の作業効率と標準化を図ることができ、メリットも大きいと思われます。
3 Comments
EvanGu
Translation:
I want the iMate can be included in iFeature.
For example, iFeature could be used when the size and the shape of a mounting hole of a connector are defined. The mounting part to the hole is also defined in this situation, if the iFeature that contains iMate can be loaded, it is efficient and standardized to assemble the components, the merit looks big.
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
