Hole with double countersink
It would be interesting to add an option in Hole feature to allow users to create a countersink/chamfer at the end of the drilling. Like a Countersink Seat Type and a reverse countersink at once, instead of adding a chamfer on each hole after creating them. Of course, this option would only be able with through holes.
Additional optionAdditional option
Result exampleResult example
6 Comments
CCarreiras
By the way, the same option for counterbore hole type.
I would like to have all the seat types available on both sides of the hole.  PTC Creo has this feature so lets make Inventor better.
MoshiurRashid
It will be well if there is a "mirror" function in the hole command. That will cover all type of hole's double features.
A mirror function won't always work in my application because you may want to use different seats on each side of the hole.  In my experience, I would need a counterbore on one side and a countersink (chamfer) on the other.
I put this same idea in (albeit without the graphics) back in 2017
https://forums.autodesk.com/t5/inventor-ideas/counterbore-countersink-holes-at-both-ends/idi-p/72164...
tstoutYZ3MS
SolidWorks has had this for the past 16 years
