The company I work for manufactures machine frames which include a number of large aluminium plates. The plates contain blind holes on both sides of the plate, and through holes. Due to the amount of holes on the plate the drawing will require front and rear views of the plate, with each view having its own hole table.
It would be useful if:-
- You could rotate the axes around X or Y (in the same way that you can rotate the UCS in AutoCAD) so that the hole co-ordinates of the front and rear views are in the same direction.
- An axis identifier rather than the basic origin indicator was available. Maybe the origin indicator could be a selectable type?
- Through holes are only included on one views holes table, maybe based on the side their sketch was created on. (Inventor knows when dimensions have been retrieved, why not holes in table)
- The hole tags would continue on across the views preventing confusion. i.e if one particular hole size ended at A14 of the front table, the same size hole would start on the other table at A15.
- Easily add geometric tolerances to holes in a table.
I didn't want to add these to https://forums.autodesk.com/t5/inventor-ideas/hole-tables/idi-p/5553918 which includes a lot of good ideas for hole table improvements.
Regards
