Have the Update button in part propetries do a Rebuild All
After opening multiple part files, it's been noticed that the volume calculation in the Properties dialog does not agree with the volume shown in the iProperties dialog.  If the iProperties dialog is used first, then the same volume is shown in the Properties dialog.  Performing a Rebuild All prior to using the Properties will also result in the same volume in both locations.  Sometimes the local update icon will be active to indicate that the model should be updated but this is not always the case.
It is disconcerting that an incorrect volume might be displayed.  I'd suggest that when the Update button is used in both the iProperties and Property dialogs that a Rebuild All be performed so that correct values will be displayed in all cases.
The attached screen cast and images show the process on an imported STEP file.  Note that the Local Update icon is not active in this example.
Screencast will be displayed here after you click Post.
8c4596b9-2287-464b-af11-47c79fe17824
