Group drafting entities
Please Add a option to "Group" of multiple drawing entities in Inventor Drawing module. If we group the drawing entities include Annotations, we can move together and position it in Sheet.Include Api for this operation to do in ilogic also. if group multiple Notes like Make it as Block in Autocad, we can move together and Positon it in single move, otherwise i have to select mutiple times to position it later.
2 Comments
jtylerbc
In what situation is this needed? Most annotations already follow the view they are attached to, so they are already (indirectly) grouped together.
sripandian
in Most of legacy drawings particularly in note section each notes they created separately in that GD&T symbols also exist. we can't select each notes with GD&T every time and move to some other location. we may use window select, but in my case i can't use because some notes are not located properly. If i position and group together like block i can move the notes with GD&T .Later if required we can select one note and move together with all, it will allow to re position the notes any place as per convenient.
