In the Bend tool and Face tool in the sheet metal environment, I want to be able to control the position of the bend similar to the flange tool.
Currently, when you select parallel faces to connect in the Face or Bend commands, the software will place the start of the bend radius at the edge of the material. For my case, I want the generated flange's face to be flush with the edge of the material. This would be equivalent to toggling from "Bend from the adjacent face" to "Inside of bend face extents" in the flange tool.
