General setting of precision to all digits for measurement inside a command
With Inventor 2017.2 the precision of the measurement tool also applies to
the measurement inside a command Dialog.
That is awful, rounded values are not the thing I want in this situation.
E.g. a chamfer has a lenght of 47,324031663 mm. If I want to
bend a sheetmetall flange with exact this flange length and use measurement
inside the flange command it leads to inaccuracy.
When the measurement Tools precision is set to 2 Digits, I get 47,32 mm, in former Releases
I got the correct value of 47,324031663 mm.
So I want the old behavior back or an Option to set it application wide, for all documents.
Best Regards
Wolfgang
2 Comments
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can, based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
